Ability to "long tap/touch" effect in stomp mode to access parameters
When in stomp mode and using quite cortex live with the eight stomp effect visible, it would be fantastic if you could Long touch/hold on the effect to have it go straight to the perimeters. Right now the tap just turns it on and off the same as the foot switch and if you want to edit any parameters you have to go back out of stock mode to your main layout, remember which Drive) it was you were trying to edit, tap on it and change the perimeters. It would be ideal if in stock mode you could see that it is the “TS Drive” and just touch and hold to access the parameters in case you needed to quickly change the gain, tone or volume.
Thanks,
Derek
There’s already a HUGE request for hold functions. Others want this mostly to turn stomps on momentarily, or have ramping abilities on effects parameters, etc. Accessing block parameters wasn’t part of that discussion, to my knowledge, but check it out.
EDIT 1/24/2024: I’ve been corrected. The OP is about hold functions on the screen. Leaving my original comment above.
dcs68 is asking for additional functions on long tapping (holding) the touchscreen. The thread you linked is about long pressing the physical foot switches. Two different things in my opinion. Love the idea, but ran out of votes :frowning:
Just wondering if there is any way for me to edit my post. I dictated it with Siri and just realized that there are all kinds of typos :). I went to the post but I don’t see the ability to edit or revise?
Thanks
@DavidRSTV I saw this…
…and it brought to mind all of the discussions we’ve all had about hold functions.
Yeah, but in the thread you linked it’s all about holding one of the hardware switches. Tapping and holding one of the elements on the touchscreen should be a different request thread imo.
