Where to buy color-coded 1/4" jack nuts?
I would like to replace some of the nuts on the back of my Quad Cortex with colored versions to make the connections easier to spot, similar to the ones shown in the photo below.
I am looking for high quality parts. I have seen a few options online, but they look like cheap plastic or someone selling 3D printed parts. Any suggestions would be appreciated. I am US-based, but if you have non-US purchase options, those may still be helpful if others are looking for the same thing.
Photo credit: https://youtu.be/hzzGWMJZUoM?si=PIi--LqbM-a0hIAG&t=342
If you’re looking for what should be a quality product, Neutrik makes these parts, labeled as NRJ-NUT-_. But I only see NRJ-NUT-R for red, NRJ-NUT-B for black, and three metal types:
This looks decent, though:
As an electrical engineer I spend a big chunk of my workday looking for parts. I hope this helps.
Thank you! You gave me some new search vectors :slight_smile:
https://www.newark.com/c/connectors/connector-tools-accessories/other-connector-accessories?st=cliff+nylon+nut
It looks like CLIFF has more color options than Neutrik; here are the part numbers I found for 1/4" (6.35mm) nylon nuts:
  • CL1408 - BLACK NUT FOR S2 JACK SOCKET
  • CL1409 - WHITE NUT FOR S2 JACK SOCKET
  • CL1410 - GREY NUT FOR S2 JACK SOCKET
  • CL1412 - BLUE NUT FOR S2 JACK SOCKET
  • CL1414 - GREEN NUT FOR S2 JACK SOCKET
  • CL1416 - RED NUT FOR S2 JACK SOCKET
  • CL1420 - YELLOW NUT FOR S2 JACK SOCKET
Good find. Newark is in the UK, so you may wind up spending more in shipping to the U.S. than for the parts themselves.
Colored Jack Nuts and Matching Cable Markers — Gear by CEBA
For genuine Cliff parts, Newark actually had the best price and lowest shipping cost from what I found online. Cliff is UK-based, Newark is in the US, but both are global companies. Newark’s shipping rate is $9.99 for the order, so as you said, it is as much as the parts themselves! The Newark price was roughly $0.30-0.50 each, depending on color and quantity ordered.
Unfortunately, Newark is currently out of stock on the blue ones, and I did not want to split the order and pay shipping twice. I ended up ordering from TME instead. They were a little more expensive ($12.90 shipping), but had everything in stock. We’ll see how long it actually takes to receive the order :slight_smile:
https://www.tme.com/us/en-us/katalog/connectors_46/?queryPhrase=Cliff%20CL14
