Using real pedalboard with Nolly!
Hey!
I’m looking to integrate my full pedalboard with the Nolly plugin, and I want to make sure I’m routing things correctly especially my (wet) time-based effects.
Here’s my current setup:
•The board includes multiple gain stages, modulation, delay, and multiple reverb pedals
•I’m planning to run direct from the last gain stage into my audio interface, then into Nolly
•I want to preserve the wet effects (mod, delay, reverb) and ideally run them after Nolly, as part of a virtual effects loop
My questions:
I- ⁠What’s the best way to route my wet effects around the Nolly plugin? Should I split the signal before the wet section and blend later in-the-box, or would a reamp/send-return style approach work better?
II- ⁠I’m considering upgrading my interface. The SSL II+ MKII is on my list due to its great preamps and multiple outputs. Would that be a good choice for setting up external routing like this, or would you recommend something more flexible for hybrid pedal/plugin workflows?
Looking to keep my analog tones intact while using Nolly’s amp sims for versatility. Any advice or alternative interface suggestions would be appreciated.
I have looked into a lot of things like getting a Helix/Cortex/Preamp Pedal to incorporate my setup but overall I really really like Nolly and seems the most logical way for me to go to use in home recording situation, they really nailed this plugin. kudos to both nolly and neuraldsp
Any help is greatly appreciated!
