Transparent Blend Source Freeze (bug?)
CorOS Version: 3.0.0
Describe your issue:
When I create a Transparent Blend on row 4 with 100% Blend, ).0 dB Output and the Source to a Freeze block on Row, the sound on both rows becomes very garbled with digital clipping.
  1. Create a freeze block on row 3
  2. Create a transparent blend block on row 4
  3. Assign the freeze as the source
I expected this to happen:
When I do this, I expect the audio sent out of the freeze to go to the blend block.
  • I am new. I came here.
If I understanding your description, you are blending the freeze signal with the original signal. If that’s the case, you may be hearing some phase cancelation between the two signals. Are you hearing the “garbled” sound when listening to the freeze signal by itself?
huh, I wonder if that’s what my Freeze was doing last week. Going to have to see if I can duplicate. I didn’t have a blend on my preset, but the Freeze was creating some pops and cracks- I thought a drum machine was bleeding thru for a second. Maybe it’s a Freeze bug
