When I use tap tempo the tempo numbers change but the tempo does not. I’ve tried in global preset and scenes. No go. I also want to map a specific delay to tap tempo and not another. Helix is easy but I don’t see any help in the manual or YouTube on this.
Thanks. Yeah I do double tap and I do see the tempo number change but the actual delay does not change. And I don’t see a way to map tap tempo to a specific delay
Are you talking about sending tempo midi mapping to a delay?
Or just setting different delays to different tempos within a preset? (If it’s this, you just turn on the “synch” function in the delay’s editing menu)
I’m not receiving midi info aside from scene changes (from MC8), and not sending midi. My understanding is synch is for synching with received info. To start , I’d be happy with tap tempo working for a single delay. It doesn’t work at all.
Thanks
sorry, I guess I’m not quite understanding the situation.
Hopefully someone else has some ideas.
@mondocongo in the spirit of helpfulness, you’d probably get your answer if you post a link showing what the helix does (“Helix is easy”).
Got it sorted. Thanks
