Hello, about stereo to mono option: If I have a stereo preset, and I choose Output 1 (or 2) mono at the grid, is the output summed or it’s just the left (or right) portion of the stereo signal?
              Couple of threads on this topic, including a feature request:
    So, confirming what’s been said on here but thought I’d try a setup for myself, nothing beats getting your hands on to learn how something works. Here’s what I did;
Took outputs 1&2 to two separate monitor speakers,  i setup the lane output to 1&2 and put a ping pong delay at the end of the chain. The delay did exactly as expected, I heard the deley going from left to right. I then pulled the right XLR out of the QC and the delay effectively doubled in time, in other words I was only hearing on…
    Thank-you for adding the Multi-out feature in firmware 1.0.3.
The only problem is that since I use a mono power amp for on-stage monitoring, this feature is really not usable in my setup without a stereo sum box.  Ideally this setup should work with minimal extra equipment and cabling.
It would be great if there were at least one multi-out mono option, so I’ll propose the following additional output options:
Multi-out 1/2, 3, 4    (I.e. 1/2 stereo, 3 & 4 summed to mono).
Multi-out Mono (…
