Good evening everyone! i have an issue that i’m still trying to figure out. basically i’m using the QC with the amp now with the 4CM and i’m trying to use the QC models with the tube amp but i want to know how to set the grid. i searched online how to set the grid and all i did get is to set the grid without a cab and without an fx loop but it’s sounds so harsh. when i put the cab on, it sounds like double cabbing and if i use the fx loop it sounds harsh as well! now the only thing different from the standard 4CM is that i’m plugged into the 2nd input of the amplifier since the 1st input is not working. the amplifier is this: Peavey ValveKing VK112 50-Watt 1x12 Guitar Combo. any suggestion would on how to setup the grid with the models with the tube amp would help! thanks!
