CorOS Version: 2.0.0
Describe your issue:
Using it as Outout Block, as Send or as full Loop results in 3 different output levels. Makes no sense to me at all? I think this is is a bug, whether it is software related or not.
Output Level is 2.3 dB higher as Output Block usage when used as Send Block.
Output Level is 4.6 dB higher as Output Block usage when used as FX Loop Block.
- Take an empty Patch and use a pink noise signal or similar sent from your DAW/Interface via TS/TRS.
- Connect Send 1 of the QC to an input of your Interface/DAW and measure the level coming in.
- Go through the 3 ways to send signal out of Send 1 (Output block, Send block, FX Loop block)
I expected this to happen:
I would expect to get back the same levels for all 3 ways to digitally route the signal out of QC Send 1.
- as a solution I apply negative gain on the Send 1 Output settings if used as Send block or FX Loop block
