I have a problem with DAW on Windows. I tested recording on Ableton 11 and Ableton 12—when I try to enter the Output settings (to be able to select output 3), the program shows an error and crashes.
I also tested Adobe Audition and Cubase—they do show the outputs, but ultimately it’s the same: after selecting, the program freezes and crashes.
In each of these programs, additionally, playing back a backing track from the DAW results in the entire signal being routed through the NanoCortex.
I’m not sure if it matters, but in the Windows volume panel, it shows two input channels to choose from: “Nano Cortex 1+2” and “Nano Cortex 3+4”. Outputs: “Nano Cortex 1+2” and “Nano Cortex 3”
Is anyone using any DAW without these types of problems?
