I know that some of the plugins can’t be used at this point but I was wondering if I purchased them (petrucci and Wong) can I add them to the plug-in menu even if they’re not available to use.
What is the plugin menu you are referring to? When the plugins become QC compatible, they will automatically be added to CoreOS and you would simply purchase/register via iLok to utilize etc.
I already purchased the plugins and had the ilok release the license. I don’t see them listed on my plug in menu even if they are disabled. I just wanted to make sure I followed the process correctly. I was aware that they wouldn’t show up until they were compatible, just wanted to make sure.
Thank you for the response.
Yeah no worries. Assuming they are made compatible, they will show up (automatically) on everyone’s QC after they update their QC firmware. So to answer your question, no you won’t add them, they will be added automatically and if you are purchased, licensed and registered with iLok, they will automatically be enabled (once you connect your QC to the Internet).
