Something like keyztone ExChanger Pickup Remodeler
Or something like The Mooer Tone Capture GTR.
Could work like this:
1-capture the sound of your reference pickups
2-select one of your reference pickup (the one curently in use)
3-select a available model or one of you captures
4-that is it, now play guitar (or bass)
This will give the possibility to bring only one guitar on set, and still be able to adapte pick up per song.
+1
to push up my lousy cello pickup signal.
Feature Proposal: Generic Pickup & Tone Conversion Block
Core Concept
Add a Generic Conversion Block to the signal chain that allows users to seamlessly transform one type of pickup sound into another in real-time (e.g., transforming a high-output humbucker into a vintage Strat single-coil, or a magnetic pickup into an acoustic guitar emulator).
Key Use Cases
Pickup Swapping On-The-Fly: Switch guitar characteristics instantly without needing to physically change guitars or hardware (e.g., going from modern rock humbuckers to glassy blues single-coils mid-set).
Acoustic Modeling: Transform an electric guitar signal into a rich, resonant acoustic guitar emulator directly within the digital signal processing (DSP) chain.
Versatility in Studio/Live: Reduce gear dependency and expand tonal palettes using a single instrument.
