Hi There!
I have a new interface in my studio. It has multiple outputs for monitoring. I use the Parallax plugin standalone for bass to the headphones. With the previous one I could only choose the name of the device (LR) as outputs even though it had seperate earphone mixes. It was routed to the DAW channel on every mix.
Now at the Parallax settings I can choose only one separate mix for the output so it will not appear in every headphone.
Is there a solution to route the Parallax more than 2 outputs?
Thanks!
