When using minivoicer the harmonies 1 and 2 have no volume, can only hear them by pushing the mix to 100% wet and the volume is super low. With the mix 50/50 sounds like 97dry/03wet. It happens with and without other effects or amps on the grid. The pan is in the middle for the dry and the harmony 1 and 2. Im using the outputs 1 and 2. This is all after the last update. I tried factory reset and still happening.
Mine is working, but the default got set to some weird levels.
I had to switch it out of Chromatic mode, and increase the individual Voice levels a LOT. The default levels were inaudible
Happening to me too, in my old minivoicer presets the harmonies are inaudible
has anyone reported this to Support@neuraldsp.com yet?
Same here.
After updating to CorOS 4.1.0, the harmonies were extremely small in volume with the old preset.
I used the NDSP default Device Presets (new feature) and the sound seems good for me, but it’s wierd.
Same here. Suddenly my Minivoicer won’t pass anything through unless I crank it up to max and even then it is useless. Even downloading an older backup won’t fix it. This is quite frustrating. Shows are just around the corner.
Yes please someone report to support. They need a ticket. Without a ticket this is olny a complaint on the forum.
You can do it!!
Aye, I’m another victim. Minivoicer sounds like it’s coming through headphones when both L&R pushed to the centre and 100% volume and 100% wet.
I’ve got a show to do tomorrow, so lucky I checked. The Multivoicer works. I’ll need to try that (I don’t like that one though)
Same here.
The minivoicer is broken since 4.10.
The multivoicer is a useless replacement since it doesn’t follow the key and it has terrible latency.
Neural, please fix this!
Neural is not going to see this info unless someone reports it to Support@neuraldsp.com
I can’t recreate a ‘broken mini-voicer’ or I’d do it myself.
To anyone having these issues, have you tried the suggested fix? The problem seems to be that the default settings have the individual Voices levels too low. Have you tried adjusting these but you’re still having problems?
also, I’m finding the Multivoicer pretty impressive, with no latency. If you are experiencing that, have you set the DELAY parameter to 0?
I CAN CONFIRM THE MINIVOICER ISSUE AFTER UPDATING TO CorOS 4.1.0
I can confirm the same MiniVoicer problem on my Quad Cortex after updating to CorOS 4.1.0.
I have already submitted a detailed report about this issue directly to Neural DSP Support at support@neuraldsp.com.
Before the update, I had several existing presets using MiniVoicer which worked correctly. After installing CorOS 4.1.0, the harmony voices in these presets became extremely quiet and are now practically unusable.
This is a serious issue for me because some of these are live presets that I actively use and urgently need for performances. Presets which worked correctly before the CorOS 4.1.0 update are now effectively non-functional because the MiniVoicer harmony can barely be heard.
TESTS I PERFORMED:
- EXISTING PRESETS / SCENES
My existing presets correctly recall the MiniVoicer settings, including different Keys/Roots assigned to Scenes (for example C Major, Bb Major and A Major).
The MiniVoicer block is active and the selected Key/Root changes correctly when switching Scenes.
Therefore, Scene parameter recall appears to be working correctly.
- MIX TEST
With Mix around 50%, the dry guitar signal is at its normal level, but the harmony voice is extremely quiet and almost inaudible.
I also tested MiniVoicer at 100% Mix.
The generated harmony IS present, but its output level is still extremely low.
- INDIVIDUAL VOICE LEVEL TEST
Regarding the suggestion to increase the individual Voice Levels: yes, I tested this.
Increasing the individual Voice Level makes the harmony somewhat more audible, confirming that the harmony signal is actually being generated.
However, even with a substantial increase, the result remains far below the normal and previously usable level.
For me, excessively increasing Voice Level is NOT an acceptable workaround.
It requires abnormal gain compensation, can negatively affect the noise floor and sound quality, and changes the balance of presets that were correctly adjusted and working before CorOS 4.1.0.
Most importantly, even after substantially increasing Voice Level, I was still unable to restore the normal MiniVoicer harmony level I had before the update.
- INTERVAL TEST (+3rd vs +8th)
I also tested different harmony intervals.
For example, changing Voice 1 from +3rd to +8th correctly produces the octave.
However, the generated octave remains at the same abnormally low level.
This suggests that pitch detection and interval generation themselves are working correctly.
The problem appears to be related specifically to the level of the processed/harmony signal generated by MiniVoicer.
- TEST WITH A FRESH MINIVOICER BLOCK
To exclude the possibility of corrupted parameters in an old preset, I created a COPY of one of my existing presets.
In this copy I removed all Pitch blocks and inserted a completely fresh MiniVoicer block.
The same problem remained.
The harmony voice was still extremely quiet.
Therefore, this does not appear to be simply a corrupted old MiniVoicer block or an incorrectly recalled parameter.
- DIRECT A/B TEST: MINIVOICER vs MULTIVOICER
This was the most important test.
I tested the new Multivoicer introduced in CorOS 4.1.0 using:
- the SAME Quad Cortex,
- the SAME guitar,
- the SAME signal chain,
- and comparable harmony settings.
The result:
MULTIVOICER:
Harmony voices have a normal, clearly audible and usable level.
MINIVOICER:
Harmony voices are extremely quiet and practically unusable.
This direct A/B comparison strongly suggests that the problem is specific to MiniVoicer rather than my guitar, routing, output levels, preset structure, or general Quad Cortex configuration.
- MULTIVOICER DELAY
Regarding the Multivoicer latency/delay question mentioned above:
I tested the individual Multivoicer Voice Delay parameter.
With Detune = 0 and Delay = 0 ms, the dry guitar and harmony voices play together without an audible delay in my test.
So the new Multivoicer itself is currently working normally for me.
CONCLUSION
Based on these tests, this appears to be a MiniVoicer-specific regression after updating to CorOS 4.1.0.
The harmony generation itself is working, but the processed harmony output is at an abnormally low level.
This is particularly serious for users who already have live presets built around MiniVoicer.
Rebuilding all existing presets around the new Multivoicer should not be necessary simply because of an operating system update. These MiniVoicer presets were created, balanced, tested and used successfully before CorOS 4.1.0.
In my case, some presets that I urgently need for live performances are now effectively unusable.
I have already sent these findings directly to Neural DSP Support.
I hope Neural DSP can reproduce the issue and provide a fix in an upcoming CorOS update.
If useful, I can provide screenshots, preset settings, or perform additional tests.
Best regards,
Marián Marko
SLOVAK VERSION / SLOVENSKÁ VERZIA
MÔŽEM POTVRDIŤ PROBLÉM MINIVOICERU PO AKTUALIZÁCII NA CorOS 4.1.0
Môžem potvrdiť rovnaký problém s MiniVoicerom na mojom Quad Cortexe po aktualizácii na CorOS 4.1.0.
Podrobný report o tomto probléme som už odoslal priamo na Neural DSP Support na support@neuraldsp.com.
Pred aktualizáciou som mal niekoľko existujúcich presetov používajúcich MiniVoicer, ktoré fungovali správne. Po nainštalovaní CorOS 4.1.0 sa harmonické hlasy v týchto presetoch stali extrémne tichými a v súčasnosti sú prakticky nepoužiteľné.
Je to pre mňa závažný problém, pretože niektoré z nich sú live presety, ktoré aktívne používam a nevyhnutne potrebujem pri vystúpeniach. Presety, ktoré pred aktualizáciou CorOS 4.1.0 fungovali správne, sú teraz v podstate nefunkčné, pretože harmóniu MiniVoiceru takmer vôbec nepočuť.
TESTY, KTORÉ SOM UROBIL:
- EXISTUJÚCE PRESETY / SCENES
Moje existujúce presety správne načítavajú nastavenia MiniVoiceru vrátane rôznych Key/Root priradených jednotlivým Scenes (napríklad C Major, Bb Major a A Major).
Blok MiniVoicer je aktívny a pri prepínaní Scenes sa zvolená Key/Root správne mení.
Načítavanie parametrov Scenes teda podľa všetkého funguje správne.
- TEST MIX
Pri Mix približne 50 % má suchý signál gitary normálnu úroveň, ale harmonický hlas je extrémne tichý a takmer nepočuteľný.
MiniVoicer som otestoval aj pri Mix 100 %.
Generovaná harmónia TAM JE, ale jej výstupná úroveň zostáva extrémne nízka.
- TEST INDIVIDUÁLNEHO VOICE LEVEL
Pokiaľ ide o návrh zvýšiť individuálne Voice Levels: áno, otestoval som to.
Zvýšenie individuálneho Voice Level spôsobí, že harmóniu počuť o niečo viac, čo potvrdzuje, že harmonický signál sa skutočne generuje.
Ani pri výraznom zvýšení však výsledok nedosahuje normálnu a predtým použiteľnú úroveň.
Extrémne zvyšovanie Voice Level pre mňa NIE JE prijateľné dočasné riešenie.
Vyžaduje neprimeranú kompenzáciu gainu, môže negatívne ovplyvniť odstup signál/šum a kvalitu zvuku a zároveň mení vyváženie presetov, ktoré boli pred CorOS 4.1.0 správne nastavené a fungovali.
A čo je najdôležitejšie, ani výrazným zvýšením Voice Level sa mi nepodarilo obnoviť normálnu úroveň harmónie MiniVoiceru, ktorú som mal pred aktualizáciou.
- TEST INTERVALU (+3rd vs +8th)
Otestoval som aj rôzne harmonické intervaly.
Napríklad pri zmene Voice 1 z +3rd na +8th MiniVoicer správne vytvorí oktávu.
Vytvorená oktáva však zostáva na rovnako abnormálne nízkej úrovni.
To naznačuje, že samotná detekcia výšky tónu a generovanie intervalov fungujú správne.
Problém sa podľa všetkého týka konkrétne úrovne spracovaného/harmonického signálu generovaného MiniVoicerom.
- TEST S ÚPLNE NOVÝM BLOKOM MINIVOICER
Aby som vylúčil možnosť poškodených parametrov v starom presete, vytvoril som KÓPIU jedného zo svojich existujúcich presetov.
V tejto kópii som odstránil všetky Pitch bloky a vložil úplne nový blok MiniVoicer.
Problém zostal rovnaký.
Harmonický hlas bol stále extrémne tichý.
Preto sa nezdá, že by išlo iba o poškodený starý blok MiniVoiceru alebo nesprávne načítaný parameter.
- PRIAMY A/B TEST: MINIVOICER vs MULTIVOICER
Toto bol najdôležitejší test.
Nový Multivoicer pridaný v CorOS 4.1.0 som otestoval s použitím:
- TOHO ISTÉHO Quad Cortexu,
- TEJ ISTEJ gitary,
- TOHO ISTÉHO signálového reťazca,
- a porovnateľného nastavenia harmónie.
Výsledok:
MULTIVOICER:
Harmonické hlasy majú normálnu, jasne počuteľnú a prakticky použiteľnú úroveň.
MINIVOICER:
Harmonické hlasy sú extrémne tiché a prakticky nepoužiteľné.
Toto priame A/B porovnanie výrazne naznačuje, že problém je špecifický pre MiniVoicer a nesúvisí s mojou gitarou, routingom, výstupnými úrovňami, štruktúrou presetu ani celkovou konfiguráciou Quad Cortexu.
- MULTIVOICER DELAY
K otázke oneskorenia/latencie Multivoiceru spomenutej vyššie:
Otestoval som individuálny parameter Voice Delay v Multivoiceri.
Pri Detune = 0 a Delay = 0 ms hrajú v mojom teste suchá gitara a harmonické hlasy spolu bez počuteľného oneskorenia.
Nový Multivoicer teda u mňa momentálne funguje normálne.
ZÁVER
Na základe týchto testov to vyzerá na problém/regresiu špecifickú pre MiniVoicer po aktualizácii na CorOS 4.1.0.
Samotné generovanie harmónie funguje, ale výstupná úroveň spracovaného harmonického signálu je abnormálne nízka.
Je to obzvlášť závažné pre používateľov, ktorí už majú live presety vytvorené okolo MiniVoiceru.
Nemalo by byť potrebné prestavať všetky existujúce presety na nový Multivoicer iba kvôli aktualizácii operačného systému. Tieto presety s MiniVoicerom boli vytvorené, vyvážené, otestované a úspešne používané ešte pred CorOS 4.1.0.
V mojom prípade sú niektoré presety, ktoré nevyhnutne potrebujem na živé vystúpenia, momentálne prakticky nepoužiteľné.
Tieto zistenia som už odoslal priamo na Neural DSP Support.
Dúfam, že Neural DSP dokáže problém reprodukovať a poskytne opravu v niektorej z nasledujúcich aktualizácií CorOS.
V prípade potreby môžem poskytnúť fotografie/screenshoty, nastavenia presetov alebo vykonať ďalšie testy.
S pozdravom
Marián Marko
They will probably request a video.
I’ll submit a report re: the Voice level issue- the more reports they get, the better.
The point here is how many people identify this problem. Because this kind of use of the harmonizer is not common to everyone. You need to know a little theory and know how to use it. In any case, they should solve it quickly. I currently have several important presets that are not working.
it’s for Community assistance. To get it properly logged and dealt with, it needs to be communicated directly to support along with a diagnostics report from the QC.
the Forum description:
“If you are experiencing issues with your Quad Cortex, it is recommend you visit cortex-support.neuraldsp.com and contact the support team. Our support team cannot quickly help you here.”
In my opinion, they should have someone on the board (behind the NeuralDSP team) who at least monitors it a little and provides information to the company, and not just passively wait for someone to announce what.
- Podľa mňa by tu mali mať niekoho na fore (za team NeuralDSP), kto to aspoň trochu sleduje a dáva info do firmy a nečaká sa len pasívne kto, čo oznámi.
it’s possible that they do, but we don’t know for sure. They definitely monitor the Feature Requests.
I just figure it’s best to remind everyone to submit their reports directly either way.
Every so often a big debate erupts here centered on what good an official forum with little official input offers, but it’s better than nothing!
Id rather NDSP spend labor hours on implementing feature requests rather than browsing this site to read posts that theyve already said they wont read because people dont want to report bugs directly. Reporting a bug just requires copying and pasting what you’ve written here into an email.
I did, 5 days ago but never got a reply, today I resend them the same email asking if they got the first one.
I’ve seen Mods in other forums confirming that NDSP is officially aware of the issue.
Usually they respond pretty quickly; check your spam/trash folders, and perhaps a Mod here can intervene directly and make sure Support got your report.
