Stephen
December 16, 2025, 9:15pm
1
Would it be possible to have a master plugin so that you don’t have to swap between the different ones. I own three plugins it would be nice to have all of the sounds/amps/effects available from one location rather than having to swap them out.
The idea for a “hub” has been kicked around, but there’s absolutely no word from Neural that this would ever happen. You can mix and match effects by loading multiple instances of plug-ins in your DAW, however annoying it may be.
Hi,
I’m aware this has been requested for a while now - a hub software with which all the standalone gear can be interchangeably loaded and combined. Just adding to the bandwagon, I think everybody would appreciate at least an update as to whether it’s being worked on or not.
I don’t understand why the last thread was locked, this is not the first time this has been raised. I love all your offerings but we need a way to cycle through presets from different archetypes/amps without having to use third party software (mainstage etc).
If not for me, do it for my midi pedal :~(
Hello,
Did you consider to create some app like plugin Hub?
App that will contains all plugins in one standalone app. All amps, all pedals and others in one app.
It should be easier to use pedals from one plugin, amp from second etc and configure it to play live.
If you didn’t consider that please think about it. It would make my life simpler and I think not only my
Thanks!
Hello folks,
Since I am completely addicted to NDSP Plugins and the Quad Cortex, I thought to myself, why this company wouldn’t just bring out a Plugin Rack Unit, in which you can insert a fully custom Signal Chain with the Plugins you bought.
I think, this would be completely insane for workflow and sound design. That way we can arrange our signal chain with our favorite FX from our plugins, without chaining 5 NDSP Plugins in a row (my poor PC).
I do not know if this is actually reasonable i…
