In Cortex Control, expanded menu for capture block to select and sort captures
In Cortex Control, downloading and testing different captures is a tedious process that requires a lot of clicks and panel/menu drill down.
So one way to improve that would be to add a pop up list in the capture block panel, similar to the pop up list of the IR block, where you can list and select your IRs.
So on that new pop up list , we would need to see an extensive list, with all the capture parameters like author, gain, type etc….and of course the ability to rename, delete, reorder etc….
That would save a lot of time moving around different panels just to delete a capture you tested and dont like.
