Capture sets and capture workflow improvements
Apologies if this is a duplicate, I tried looking through requests and searching lots of different combinations.
I’d love if when capturing you could choose to capture multiple settings as a set. There could then just be a dropdown to select the specific capture on the block. It’d really clean up navigation and be way less hassle downloading/deleting stuff.
It’d also be great if after capturing a different setting you could switch between the other captures in the set to check there’s no massive volume changes etc. So annoying spending ages capturing only to realise a couple of them sound way off compared to the others. Also uploading the same image and description to 20 captures of the same pedal is tedious!!!
I know Tonehunt/Tone3000 has something similar for grouping captures but it’s pretty basic, could be done way better.
