I’ve moved on to a phase in which I haven’t actually looked at the interface or changed any settings in a while. I’ve found a preset I like. I just flip the switch and play.
I’m sure I’ll start experimenting again with the new release, but I’m definitely not second guessing the QC at this point.
I have not looked since I put
them on but I m pretty sure they’ll be fine just don’t go so extremely tight so that they’ll dig in and that goes for any buttons. I do not like the mooer buttons . I just don’t like the looks of them. Everyone has different tastes though. I not only like the soluteks looks and rubber inserts they match perfectly.
I had too many typos at the beginning. Deleted sorry. I need to double check more when I post. Basically said not bored with it. But not giving up my amps or pedals. It is my favorite modeler though in feel and sound and UI.
lol @spikey, you should read my post completely and not just the first sentence, as i explicitly explained my point based on exactly this video…
“These are pre produced shows triggering all changes via MIDI or they have guitar techs behind the stage pulling the strings. That was even explained by Kiko Loureiro himself in his QC setup video.”
There’s a newer video of Kiko and Keaton showing an updated setup (at around 3:25 in the video). They now use scenes that are covering almost all sounds he needs.
Yes, you are right, they switch by midi but nevertheless, I believe it would also be possible to switch these scenes on stage, if they wanted or needed. https://youtu.be/luRdRfq4jQY
Funny, I had the UAFX Dream pedal and sent it back to Amazon after using it once at our church. I ended up getting the QC instead. I was very happy with the Dream, but was fascinated by the potential of the QC and how well it looks and its build quality. My needs are simple, but I do really like great tone as we all do. I do believe that getting in recently was good timing and the upcoming improvements will be enough for me to want to continue learning about this amazing unit and using it to the best of my abilities.
I’ve had the QC for a month now. I didn’t find the factory presets or captures good enough for my liking but I’ve found a ton of great captures from other people on the Cortex Cloud.
Today I captured some presets from my FM3 and somehow they sound even better on the QC. It’s crazy and I love it hahah
Glad the FM3 captures turned out! Genuinely curious, which models did you not find to be accurate? Honestly the only one I’ve struggled with is the Mesa Red Modern… the bottom end is SO loose that it sounds like the speaker is blowing up! Most of the others seem pretty accurate to me (I’ve owned a few of the amps listed, several of the Fenders, a VoxAC30, Mesa Lonestar and Dual Rec).
