Help with routing
Cool, GTK. My ears are happy, and no one at any show I’ve played complained about “excessive latency”. :laughing:
128 samples to me isn’t a lot more and is still less than most digital pedals. Sure if you want the absolute least amount of latency don’t use DSP2 with its 64 sample input and output buffer, but mist people aren’t going to notice the difference.
Hey - I am sorry to be a pain, but I am trying to lay out my preset the same as you have here - when I drop my cab sim down to the split, same as you, where you have it to go to out 1/2 - I hear sound with no sim - move it back up to row 3 and everything is fine.
I am monitoring with headphones, is that why? I have it exactly as you have here. Should I be hearing the cab sim through the headphones? Output 3 would have the no cab sim?
Hey, I tried replicating the issue you’re having by plugging a TRS cable into the headphone jack, then running out to a separate audio interface. Couldn’t get any sound at all.
I’ve got my headphones at work–I’ll bring them home and test them out directly with what you’re describing. Sit tight.
Hey - I think I figured it out. For some reason I thought that what comes out the headphone jacks is only output 1/2.
I think it is all outputs - which makes sense, but it didn’t click for me.
I split outs 1/2 to my Pro Tools and 3 to a cab and BOOM - it works.
Thank you for your help and support.
if you click on the Headphones jack icon in the swipe-down I/O menu, you can control levels of what you hear from each Output that is assigned. It’s a nice little sub-mixer for the HPs- but keep in mind, what you hear in the headphones is not always the same and what you’d hear from other sources when you have multiple Outputs routed individually.
Got it - Thank you!
