Global Sum to Mono options
Please add global options to independently sum XLR Output (1/2) or Jack Output (3/4) to mono. This could be an on/off switch to the right of the mute switch in the pull down I/O Settings for Output 1/2 and Output 3/4.
This allows for the following scenario’s:
Scenario 1/2 XLR Output 3/4 Jack Output
Default Stereo Stereo
All Mono Sum to Mono Sum to Mono
XLR Mono / Jack Stereo Sum to Mono Stereo
XLR Stereo / Jack Mono Stereo Sum to Mono
This alleviates the need to have multiple identical set lists with some having a mono block at the end of the signal flow. It eliminates the admin burden of updating multiple versions of the same presets to cater for different front of house, monitoring and recording scenarios. Also removes the risk of having to carry more cables to cater for manually summing to mono.
Hello, this feature request already exists and has plenty of votes.
This requires every preset to be set up in a specific way. This request is for it to be a “GLOBAL” setting so that the summing to mono happens for all presets regardless of how they were set up. The concept being if you get to a gig and find that you have a mono front of house you can change one GLOBAL setting and you’re set. It’s a different requirement.
