Factory capture presets
Is there a way to tell what amp the factory presets are trying to emulate ? Some are obvious, but if they had a guide on this, it’d be helpful, then I won’t have to download extra captures if I like the ones they have already
Yes, after loading a preset you can see the capture being used and the capture sources can be found in the manual under the ”Factory Content” section.
Thank you. I appreciate the knowledge
I’m sorry but there’s no such “Factory Content” section to be found.
There is a link in the manual:
https://neuraldsp.com/nano-cortex-device-list?_gl=1*wa7zka*_up*MQ.._gaMTI2MTQyMjM2Ni4xNzU2NTcwMTUy*_ga_M11P2CS51H*czE3NTY1NzAxNDkkbzEkZzEkdDE3NTY1NzAxNDkkajYwJGwwJGgyNzExODM1ODU.
