Error Code 0 when doing a V2 capture
I’ve started having a new issue making V2 captures that I’m curious if anyone else has experienced it or found a solution for it. I made a few captures already using it, but I seem to now be stuck where I can’t make a new one and I keep getting error code 0 when it goes into the recording phase of the capture after the calibration check. I’ve reset both the quad cortex and cortex control and unplugged and re-plugged it in to try and clear the error. I still have storage left on the device. The signal level seem fine. I’m out of ideas.
Anyone else experiencing this?
there’s no explanatory info provided with the failure error?
Just error Code 0, which from my googling is just a generic error
went back a day later and everything is working again without a reset, I’m suspecting it was a server side issue
One last update, I got the error consistently again. Here’s what it looks like. Allegedly, there’s a 40 per day cap for V2 captures, but I got this after 7 today. I got it after 6 the other day when I got the same error, and was able to do 8 a different time before that. I think this could still be a server-side issue or they’re setting the limit much lower.
I have the same issue since a few days
Anyone have the same issue ?
