Does it matter if you add effects after the amp but before the cab? I see in the discord that seems like the only way to split the outputs if you want a cab on one and no cab on another.
As long as the effects are linear (chorus, reverb, delay, EQ - no distortion or compression), it doesn’t matter if they are before or after the cab. Similarly, as long as the blocks aren’t distorting, reverb into delay is the same as delay into reverb. Here’s a video that demonstrates the impact of cab and effect ordering: Cab and Effects Order - YouTube
