Dual Pitch/Dual detune
Please add a dual pitch or dual detuner with 2 voices in order to emulate hairy’s tones with a slight detune -10ct / +10ct in one block
At the moment we can only achieve this using two separate Pitch Shifter blocks with second one in parallel
You can do that with the Micro Processor (ST) block found in the Modulation folder. It’s an emulation of that particular effect in the Eventide H3000, and it sounds exactly as expected. It was added in patch 3.3.0 back in late November.
@tribalita, as @ScreamOfAnger stated, the effect you are looking for is the Micro Processor etc.
Let me know if this thread should be closed. Thanks!
Thanks for replies, I tried microprocessor ST but I can notice a little bit of chorusing…any idea on how can I avoid it?
Won’t a double detune always sound like chorus? The chorus effect is from 2 tones that are slightly off tune from each other. Maybe try less detuning.
Ok, post can be closed, thx!
