Configuracion global eq
Buenas amigos,
Me podria ayudar alguien a configurar la Global EQ,no entiendo muy bien de ecualizaciones y me gustaria dejarlo bien, actualmente uso un FRFR Fender Tonemaster 12 y las guitarras que uso son ESP EII HORIZON,FENDER STRATOCASTER y Gibson LES PAUL STANDARD,por si os sirve de ayuda y me podeis hechar un cable.Gracias de antemano
Hey everyone,
Could someone help me configure the Global EQ? I don't really understand equalization settings and I'd like to get it dialed in properly. I'm currently using a Fender Tonemaster 12 FRFR and the guitars I use are an ESP EII Horizon, a Fender Stratocaster, and a Gibson Les Paul Standard. Any help would be greatly appreciated. Thanks in advance.
In the manual under ‘Features’ you will find the Global EQ section which describes how to best use the feature. Essentially, you want to use Global EQ for when playing various venues and dealing with EQ differences but there are lots of uses for the GEQ feature:
GLOBAL EQ
The I/O Settings menu includes a 5-Band Parametric EQ that can be assigned to one or both output pairs.
Tap GLOBAL EQ at the top of the I/O Settings to access its interface.
  • GLOBAL EQ BYPASS: Toggles the GLOBAL EQ on or off.
  • EQ BAND TABS: Tap to access EQ band parameters. Each EQ Band will affect a specific frequency range.
  • EQ BAND TYPE: Determines the filter type for the selected EQ band.
  • EQ BAND GAIN: Adjusts the gain of the selected EQ band (-12/+12dB).
  • EQ BAND FREQ: Adjusts the frequency of the selected EQ band (20Hz/20kHz).
  • EQ BAND Q: Adjusts the bandwidth of the selected EQ band. Higher Q values narrow the affected frequency range.
  • EQ BAND BYPASS: Toggles the selected EQ band on or off.
  • OUT TAB: Assign the GLOBAL EQ to one or both output pairs and adjust its overall output level.
Global EQ & Input Gate Bypass
The GLOBAL EQ and INPUT GATE blocks are automatically disabled when a Preset exceeds available processing resources.
