DAW: Reaper
I use the standalone app perfectly fine and have used the plugins in Reaper before, however it’s been a few months since I last used it. But now when I load the Effect onto a track It doesn’t output any sound I just get the direct signal, not only does it not work on a pre-recorded track I also can’t hear it with record monitoring on or auto. There also seems to be no input as the level in the UI is not lifting. The tuner does not work, but switching between mono and stereo input modes within the plugin does work.
I’ve tried troubleshooting from many other threads from this and other forums with no success and would really appreciate any ideas.
Thank you in advance ![]()
