Anyone moved from Fractal/Kemper to Quad Cortex and why?
Bit of context…
I’m the MD and guitarist for the Queen tribute band in my country.
I was (still are!) using a Vox AC30 / G-System for my Brian May sound, together with a Treble Booster. We don’t have any haul company so we have to carry all ourselves. It was a bit fed up of carrying this weight / setup time for all the gigs (and fortunately we have a lot!) so I ended up buying a Quad Cortex (after a previous unsuccessful attempt with the Helix).
I use it for half a Tour in 2024 and returned to amp again, mainly because:
  • I could never get a satisfying AC30 at full and didn’t find any capture to use with my external Treble Booster.
  • The ONLY usable way to do it was a capture I found on cloud with the baked Treble Booster which raised several issues:
  1. For Queen, Brian uses the volume knob on the guitar to go from sparkly cleans to full fat lead tone. With this capture, the difference in dB when I did that was huge, nothing like in “real” world. So the capture was not “cleaning” per se, but also dropping volume.
  2. The Noise Gates didn’t do a very good job (I didn’t had the chance to try the new sidechaining feature tho) - the Helix one was much better, it worked like my ISP Decimator.
  3. This prevents me to use my strap mounted Treble Booster (in order to use a wireless system) because the TB was already baked in the capture
  4. There was always an annoying/harsh mids I could not get rid of - it lacks that “oooomph”, fat and defined sound
  5. Why NDSP opted for that flimsy AC adapter is a mystery to me - if it’s size/form factor, I’m sure people wouldn’t mind a bit larger/bulkier unit to have the IEC incorporated. Much more safe and secure but I also have to say that the included power supply never failed on me.
  6. The all 82.5% delay equal mix is also a concept that I cannot understand. Why not the much more intuitive 50%? My guess is that this was NOT ON PURPOSE at all and the unit just behaves this way (should have been thought thru better! - speculation of course but…).
  • After a poorly monitored gig, I ended up selling the QC (one of those “enough” moments that we all know about, on a impulse but it sold so quickly I didn’t have the time to think it thru).
Having said that, and please don’t take the thread as a bash at QC because there are a TON of other things I loved about and I really miss, just trying to give you some context on why and how I used it.
I’m looking for another modeler - of course in respective foruns, please praise Kemper or Fractal, depending on which forum we are, but would really like to read some stories of people migrating for what the owners classify as TOP NOTCH (specially the Fractal) to the QC.
Of course YMMV and my scenario is really specific - maybe if you use a more conventional amp and clean/lead approach its fine but, in my case scenario, I cannot got a sound usable for me live. Here’s an example of a Brian May tone I love. Really “fat” and lots of gain:
Many thanks in advance.
P.S. - I’m about to return to QC land because of all the PROS that sometimes surpasses the CONS but still indecisive.
I’m in a similar, yet opposite boat. I’ve been playing Kempers for the last 7-8 years and have really had nothing but extremely positive things to say about them in all areas (sounds, effects, customer service, firmware upgrades, etc.).
The only reason I decided to buy a QC (which should be arriving today) is because the Kemper is now 14 years old - and in the world of computers/processors, that’s ancient. So, I figured the QC must be better.
But after doing a lot of reading and diving into videos and a bit of the manual, I’m already concerned that the QC doesn’t stack up to the ancient Kemper. I’m hoping I’m wrong and can’t wait to get the QC today to dive in.
I feel like the captures from the QC seem to be a LITTLE better. But considering I don’t own any real amps anymore, that doesn’t matter much to me.
My biggest gripe that I’ve already got with the QC (which I didn’t understand until after I ordered it), is this: With the Kemper, you can have a bank/performance with 5 difference rigs/presets in it. Each one of those rigs can have completely different amps and effects loaded into it, with no processing power worries. Plus, you can have 4 stompbox switches on top of those 5 presets to use. So you get the best of both worlds, presets plus stomp mode. AND, you can switch between performances smoothly with no lag/latency in sound. With the QC, you can use Scene mode if you want to get 8 different sounds, but those 8 different sounds all need to have the same amps/effects pre-loaded to swap through and you’re at the mercy of processing power limitations as to what you can put in there. So if I want to have a rig that is my rhythm sound and want to be able to turn the delay on and off, I either need to waste another scene slot on that (same rhythm sound + delay), or deal with toggling back and forth between modes. Whereas with the Kemper, I can have that rhythm sound and just assign one of the stomp switches to the delay. And then the other 4 slots I have available in that performance can all be fully customized as well, with no limitations or requirements that they have the same amps/effects as the other slots.
Yes, I understand I could use hybrid mode on the QC to achieve this. But it’s not nearly as convenient as the Kemper. Hybrid mode only gives me 4 slots for scenes and then 4 stomps to utilize, and again, still requires that each scene have the same amps/effects. And, if I want to scroll up to another bank of scenes, there will be a drop in sound when switching between them (unlike the Kemper).
There is just WAY more flexibility on the Kemper in this area. And since 95% of what I use the Kemper for is live performances, that’s a big deal.
From what I’ve read (and heard) the Kemper also has the advantage in terms of effects. There are more effects available and they seem to be higher quality and have more adjustable parameters.
Another advantage of the Kemper is that it offers SPDIF inputs/outputs.
After saying all that, there are things on the QC that I think (hope) I’m going to like more than the Kemper. For example, the ability to run multiple amps at once. The smaller footprint. Better screen. Hopefully, better sounds. The ability to have more stomps and effects both before and after the amp & cab (the Kemper limits you to only 4 stomps before the amp/cab section and 4 effects after it.
Ultimately, it’ll come down to which features matter more for each person. For me, if the quality of the sounds in the QC aren’t any better than the Kemper, I’ll return it because of it’s limitations with accessing presets/scenes as I mentioned above.
Hi,
I moved recently from Kemper Stage to QC.
Kemper Wins
  • Effects quality: Huge difference between QC and Kember. Reverbs in Kemper are way better.
  • Confiability: Kemper is a tank. You can have bad energy and it continue to works. The standard power cable is also a benefit. If you forgot the QC power supply you are going to have a hard time finding a replacement
  • Organic Sound: Vintage amps/presets sounds better. They are more dynamic and responsive.
  • Outputs for Live gigs: Kemper automatically splits Monitor and PA/Output removing the cab/IR sim. That’s not the same in QC. You have to program your presets taking that into account.
QC Wins
  • Portability: It’s smaller than Kemper Stage
  • User interface: Somewhat easier to change things in a live situation
  • Modern Sounds: QC has more clarity on modern sounds.
Other things
  • The overall QC plugin situation is a mess.
  • It’s very difficult to find good captures. The Cortex Cloud has very few options compared to Kemper ecosystem.
  • EVERYTHING needs to go through Cortex Cloud: Whan’t to add an IR directly to your QC? You can’t. You need to send it to the cloud, connect QC to wifi and download it. Very very annoying.
    Want to buy some captures/presets? It’s a very difficult process.
    Kemper ecosystem is way simpler and focused on the player.
    QC is a computer/cloud centric product, not instrument player.
I’m considering going back to Kemper (mayber a kemper player instead of stage for portability) or Fractal.
As an update, I got my QC yesterday and it became very clear, very quickly that the Kemper is still a considerably better overall product (IMO). This morning, I boxed up the QC and returned it.
I agree with much of what @guidefreitas said above.The only area in terms of sound that I give the edge to is the modern sounds. But it’s a slight difference. Honestly, you can get good sounds out of either of these units. So, aside from minor differences, I’d say the sounds that you can get are a wash.
The things I liked better about the QC were:
  • The larger touch screen (very convenient)
  • The ability to run multiple amps at the same time
  • The ability to have more than 4 effects units before and/or after the amp/cab section (limited to 4 each on the Kemper)
  • The smaller overall size of the unit
Other than that, it’s all Kemper.
  • Kemper’s effects are noticeably better.
  • The Kemper is a much quieter unit (with all gates off). Even in low gain amps that are included from QC, there is a noticeable hiss and general noise that isn’t present on very similar sounding/gained amps.
  • The Rig Manager editor on Kemper is way better for previewing, sorting and ranking profiles/captures.
  • Kemper has SPDIF inputs and outputs (QC has none)
  • The ability to have 5 completely different presets in the same bank without being required to have the same signal chain in each is a MASSIVE advantage that the Kemper has. That alone is a major win, but then Kemper widens the gap even more by also allowing you to have 4 dedicated stomp buttons to assign to single or multiple effects for EACH of the 5 rigs in every bank/performance. The fact that the QC’s technology is 14 years newer but ended up limiting users in this way, is embarrassing.
And let’s not forget, the price of the Kemper is actually $300 cheaper than the QC at Sweetwater.
The QC has the potential to be great - but I think it’s going to take some time and some major upgrades via firmware to get there. Until then, for me, the Kemper is still miles ahead as an overall unit.
Thanks for the feedback, it’s a good time to be a musician with the choices we now have! I am glad the Kemper works better for your needs and good luck!
As An owner of 2 vintage Ac30’s, I can say that the Ac30 Di captures from amalgam audio are spectacular sounding.
To me they sound as good as my own amps miced up.
I did not even manage to capture my own amps to the same quality level of the amalgam ones.
The Di type capture allow to use the provided silver bell celestion IR that come with the DI captures , but there are also very good other vox silver or blue speaker IR’s available and allow for more tonal options …
My experience is gleaned from being a former guitarist within the CCM genre, then became the hired gun for rock and pop stuff (and I love metal when I’m at home, so go figure — guitarists are nothing if not eclectic!). These days I write and record at home, so that’s the perspective and background I’m coming from here.
I moved from an AxeFX to the QC for the form-factor, but I was using the XL+ before the III came out. Lugging the Fractal along with everything else in my 8U rack and roll-in gets old. Since now I am based more at home and do not gig regularly, I’ve experimented with different modellers because I enjoy the tweakability and doing deep dives at my desk. So here’s my take as someone who has played modellers for some time — worth noting that I have owned an FM3, an AxeFX 2 XL+, the QC of course, but have also spent considerable time demoing a Helix, and a Tonemaster Pro. Here’s my two cents:
QC
  • The UI is intuitive, and I find it easy to dial in an awesome tone quickly
  • The stock presets and captures give me more than enough range of flexibility for what I do now, and my experimentation with my own captures has been positive. I have captured a handful of my favourite pedals and just a few amps, and to my ears, they sound fantastic as captures
  • For simply just plugging in a unit to my recording setup and getting a great guitar sound, the QC fares better than the other options I’ve played
Fractal
  • The scope and range of effects is staggering, and what you can accomplish with Axe-Edit and an afternoon only inspires me to play more
  • As a product with decent legacy, there are more subject matter experts to lean in to for troubleshooting. When I was dialling in the tones I wanted, the community jumped at the opportunity to help me navigate roadblocks and I even received direct support from their customer service promptly
Fender
  • It felt like the modelling world’s ‘college graduate’ — really solid but kind of directionless, clearly smart out of the gate but tons of potential, and just lacking the experience to be a fully-realized powerhouse. I found a handful of effects that I loved, but only 2 amp models that I wished were on the QC. But it was built like a tank and the global eq was intuitive and easy to incorporate
Helix
  • Again, I didn’t own this but swapped with my mate to try it out, and you know how certain amps and guitars make you play a certain way? This had that same quality across many presets, so they clearly designed something that, similar to the QC, felt amazing right out of the box. And it was comical that in the weeks that I had it, a firmware update was released — so it’s clear that this unit is at the forefront of Line 6’s minds.
I’m not sure if sharing my experience is helpful, but there it is regardless. I didn’t go too deep (if at all) into the ‘cons’ of my experiences because one person’s preference is another person’s gripe. And nobody jump on me for this, but I don’t care for learning the best way to mic cabs and how to route complex pathways to achieve S-tier tone… I just like to play and don’t like doing much setup. Anything that gets me excited to strap on the guitar and spend more time playing is a good thing, and that’s what the QC does better than anything else I’ve played. Plug, play, fiddle some knobs, hit record, and I’m happy.
Kudos to you, though: I’m not in a tribute band but from what I’ve seen, when cover bands are good and care as much as you clearly do, they are gooooood so props to you for tackling Brian May’s tone! I’m sure it’s great, but your ear would be far more discerning than mine in that regard. Keep us posted on your tone journey and share samples if you can!
Hi MayPRS,
my own experience with the QC has been very mixed for different reasons.
I love the design and handling of the unit (except for the unsatisfying power supply/plug solution).
It is fantastic to have four independent inputs and that is the reason why I had bought it in the first place, despite having been a very happy owner and user of Kemper Head, Stage and Player since 2017.
So far I could not find a AC30 capture for the QC that came near the ones I have bought from Michael Britt for the Kemper. Actually the sound and playing feel of some Kemper AC30 profile is what had convinced me in the first place to get one myself.
My main issue with the QC is the reliability. It has suddenly refused to work during the soundcheck for a gig two weeks ago - simply no output signal. If it hadn’t been for my Kemper player which I had brought along as a redundant system this would have been a very frustrating gig. Some students of mine also have reported failures of the QC engine and a very reluctant behaviour of the NDSP support. It is a insecuring perspective if a machine produces major errors just once in a while which for some reason cannot be replicated.
I hope the mayority of QC users are happy with their items and the problem with mine will be solved or just disappears for good. Several professionals I know have switched from QC to Fractal. I personally don’t like the Fractal UI which on QC is surely state of the art. For me personally there is no equal alternative to the Kemper yet as far as full vintage sound, professional reliablity and quality of Delay/Rev effects. If you are out for smallest footprint and best (AC30) sound/possibilites altogether, get a Kemper Player in LEVEL III version and something like a Morningstar 6 as MIDI controller.
Your first answering correspondant @OhG is totally right though when he praises the mapping concept of the KPA with the big remote resp. the STAGE. Even though there is so much question of taste and synaesthesia involved of course. It is great nowadays to be able to choose between so many digital machines that are pretty much on the same level if you sum it all up.
I changed a while ago after over 8 yrs with kemper. I wanted a “backup” but the player was too expensive. So i got a nona cortex, really liked the sounds as well so thought why not the QC instead of my kemper stage. Did I need to change ? No … but once in a while you need to change gear to keep you fresh and motivated I guess :slight_smile: … Raf
Many thanks all for the wonderful insights!
It kinda validate what I was thinking - I did tour with the QC for 6 months and, truth be told, never had an issue but its always good to have some kind of redundancy at a gig (not only guitars!). I know some people tour with QC for 3+ years without an issue. I hate to think its a matter of “luck” and the QC (Quality Control) as well as parts used are the same but it seems its not the case?
I play with a AC30 + G-System and, of course, they also can fail, but the G-System has been rock solid for 12 years of uninterrupted gigs! Same for my AC30, although it was revised on 2024.
But I’m really tired of carrying this gear around, lots of gigs and we don’t have an haul company for the backline - only for stage and FOH.
Sounds like the real problem is load-in… I’ve got your solution!
Fernandes Nomad, sm57 duct-taped to the front of the cone, and a Temu wireless unit. Guitar, amp, speaker, and transmission all in one. Throw in some extra batteries and your entire rig will fit in a hello kitty backpack. Your tone will be so unreal they’ll start calling you Brian Maybe :smiling_face_with_sunglasses:
:joy: :joy: :joy: Light and quick setup!!
Welcome!
Both are great units. For me fractal works better for live shows. QC works great in studio, or simple scaled down shows without complex signal chains.
Fractal is a super cohesive live rig, thanks to its intuitive layout and forward thinking in terms of live playing. Gapless switching between presets on units such as the AXEFX-3 paired with the FC-12 or all in one FM9T. This seamless switching between presets is next level. It gives it another edge over the others for liver shows with complex signal chains.
QC just isn’t quite there yet in terms of what you need in a live unit… Both units offer midi switching, but gaps on the QC are much more limiting to what can be done.
On the other hand, QC offers its own advantages, particularly with its polished sounding models. They just sound great, and the effects are solid, even if they aren’t quite as refined as Fractal’s. Both units clearly have their strengths, making both top notch units.
Fractal:
• Known for a cohesive live system and intuitive layout.
• Offers gapless switching between presets, especially beneficial for live performances.
• Provides high-quality effects, making it ideal for complex stage setups.
QC:
• Compact and great for a fly-rig setup.
• Offers good effects with a polished feel, though not as refined as Fractal’s.
• Suited for studio work or simpler performances without complex signal chains.
Im coming from experience. I love both units. Own both brands flagship offerings.
I think that both the QC and Nano Cortex offer a lot when going with NDSP’s ‘ecosystem’. I had the Fractal FX2 and simply hated the UI, fast forward to when the FM9 was released and gave it up after receiving my QC mainly due to the same UI. Tone wise and excluding FX, I think they were both on par. Plenty of major players are using the QC more and more and its design is essentially future proof. The capture feature is phenomenal, I can now create and load my favorite QC captures on my Nano Cortex and take them anywhere. Integration of plugins for the QC was also a plus. I, like everyone else, wished the updates were more frequent than they are currently. I see a ton of potential in both the QC and Nano and believe we will see some exciting things in the near future updates.
As someone who switched from Line 6 to the Quad Cortex back in 2021, I still resonate strongly with the pros and cons mentioned here. Although the QC is my primary modeller and definitely wins on ease-of-use compared to the overwhelming depth of the Fractal FM9, I can’t help but feel frustrated by Neural DSP’s ongoing neglect of core features (especially the subpar reverbs). Frankly, I’m surprised they haven’t addressed this by now.
The situation with paid plugin compatibility is also messy and confusing, clearly more complicated than Neural initially anticipated. Yes, Line 6, Fractal, and Kemper had a head start (for example, the Helix inherited many effects from older Line 6 units), but Neural’s decision to release another device, the Nano Cortex, feels premature when the QC itself remains unfinished in key areas.
Even if the teams porting plugins and developing other QC aspects are allegedly separate, Neural should prioritise fixing fundamental shortcomings before expanding their lineup further. When they released the Nano Cortex I felt the sting of disappointment they decided to release more hardware to maintain before they finished their main hardware device as originally promised.
Additionally, the amp model situation needs serious attention. The current Mesa Dual Rectifier models sound terrible and desperately require remodeling. There’s an evident shortage of essential Mesa models (no Triple Rectifier, Mark IV, or Mark V). It’s also puzzling that Neural offers no modeled Orange amplifiers, relying solely on captures. Also, we badly need improved modulation effects, specifically better tremolo and flanger options.
Neural Captures are another source of frustration. There are numerous factory captures, yet none of their parameters or differences are clearly documented. For instance, having twelve “Iba Green 9” captures with no explanation forces users into tedious cycling just to find something suitable. This issue is consistent across the entire capture collection.
Their approach to presets and captures, using a walled-garden cloud system, makes buying and selling overly complicated. Users must “befriend” others on the cloud to share presets rather than using a simple, consumer-friendly file format like their competitors. This feels anti-consumer, and the entire cloud experience (despite improvements) remains buggy, slow, and unintuitive. The cloud needs a complete redesign.
I’ve even considered building my own NDSP cloud/marketplace bridge using a headless browser to handle preset management independently myself. I might even do that to be honest. I held off thinking Neural would have provided a better cloud experienced and marketplace, but I think it’s far down the priority list.
Not wanting this to be a bash NDSP comment either. Despite its shortcomings, I make the QC work and it’s my main modeller. But I do wish some of the caveats were addressed and have been patiently waiting for years for them to be fixed. Even if Neural just fixed the reverbs, I’d be happy for a good while. I miss all of the effects I had on the Helix, even back in 2021.
I agree 100% with your comments on the Nano. I don’t understand why they released it when there’s still so much to cover with the QC.
It is a pain-point because I know it’s taking resources from QC development.
I also see all these fanboys out there talking like we should all just be satisfied with our QC’s ‘just because’
No! We need to keep their feet to the fire.
As for the FM9 - I know the UI isn’t as polished. That said, I’m the type that builds my set list before playing shows.
So I almost never touch presets after they’ve been built. There’s really no need.
Anyone who’s dealing with these issues most likely should have put more effort in their preset builds before hand.
To me fractal has done a fantastic job with the layout.
QC’s GUI is nice but stomp mode and live mode are washed out and remind me of line6 HD ideas. There’s major issues with “banking” and the way that presets are executed - almost like a computer file system.
You get pulled into presets with no ability to “preview” - you are pulled into the branch and have to back out with too many steps.
I have my wishlist up, but I doubt I’ll see these changes anytime soon.
People using their QC’s using midi for set flow have less issues BUT, your limited with gaps in between presets…
Idk. I do not think it’s what I would use for live shows atm. It can be done but I trust my FM9 more atm.
You should probably check out the FM9. I’ve said this before, and it’s not me trying to fanboy for Fractal, but it has hapless switching between presets.
It also does edge of breakup like a real amp. Just reading your comment, I would deftly at least try one out.
I think you’ll love the “DynaCab” options too.
I love NDSP. I own almost all of their suites, a QC and lots of bass gear too.
TBH - I just don’t think QC is “there” yet in regards to a live rig.
I sold my first QC - I’m now back on and got the updated ver about 2 months ago now.
I love it, but I know that I won’t stop using my FM9 for live shows - unless it’s a super small venue.
I prefer the portability of the QC - that said, on a stage I just think the FM9 is the better way to go rn.
I use the QC for all studio stuff since I got it and I love how polished it sounds.
The fx aren’t there yet tho. Fractal takes the W with its fx.
I hope NDSP is able to overcome some of these issues quickly but I won’t hold my breath- especially with the release of the NC.
As for power differences between Fractal and NDSP…. To me it seems like the difference between Apple and Microsoft.
My FM9 boots in half the time as the QC. It also does way more in terms of tone too.
I had a powered kemper for a long time. But I didnt get an frfr cab or just a PA speaker to plug into to fill that role. But even if I hadnt been locked into an oversized mesa cab with the UK vintage 30’s i would still have sold it.
I never left modeling but I actually downgraded. Up until purchasing the quad I was using a hotone ampero MP100. When these things came out they sounded EPIC. I was so impressed with the onboard tones and the touch screen capabilities which really was the first touchscreen modeler available. It was small, had a built in expression pedal and is tiny but sounded huge.
But as time went on the updates added more features, sound and capabilities but they maxed out the dsp with features at the expense of the actual feel and sound. I ended up getting the quad only a couple months before the plugin compatibility so I didnt have to wait long.
But I must admit I struggled with the cortex till today. My original unit was replaced and I just got the new one today which already had the most recent sofware update installed. My old one had a screen issue develop and then when I got it back input 1 had almost zero retention on a 1/4" plug. Luckily the dealer I got it from swapped it out.
I had a lot of issues. The unit always sounded great. But I always had a loud popping noise when shutting it down. It wouldnt connect to wifi unless it was 2 feet away from the wifi box. And it was noisy. Almost as if the unit wasnt grounded. I have 3 plugins unlocked and on the old unit It was as if the noise gates didnt even work.
I got my new one today and the thing was just a dream right out of the box. Switching over to the new unit was seamless and I managed to do a backup of my old unit so all my settings,presets and plugins worked from the first time I tried logging in and connecting to the wifi in my room where I use it.
Now it sounds exactly as I thought it always should have. No buzzing or squeeling. I actually was able to turn many of my noise gates off completely because there is no background hiss or white noise. It was especially bad on the fortin nameless suite. But now its one of my favorites to mess with.
The quad I assumed was replicating the noise of the circuits of the OG they modeled. Turns out I just had a rare but ultimately defective unit. Im saying that because if you get one buy one new. Used you have no way to know if its operating properly. My new one stays really cool. Old one? I used to elevate it because I didnt feel it was staying cool enough.
But IMHO the user interface and the unlimited tones and ability to shape them make it the perfect unit. If you want an expression pedal you can buy one. If you dont need one you dont have to have the extra weight.
The sounds are incredible. I find it even easier to use interface wise than the hotone that I loved until the sounds tanked.
I was originally disappointed that the quad lacked certain amplifiers. But then I decided to stop looking at the amps as actual amps. I just look at them as tonal starting points. And when I look at it like that there really isnt a sound in my head that I cant recreate on the unit. And you can do it really quickly once you are familiar with UI.
I didnt go with a helix because it lacked some of the features I really wanted but had some that the quad lacks. Like a proper Aux in.
Now my only concern is that since development of this product is ongoing I hope that they dont do anything that compromises the unit in terms of tone. And I hope they built in enough power for them to do all that they want to do for it. They have admitted to challenges of getting all the compatibility of plugins to work in the quad. No specifics but just that they ran into more challenges than expected.
For me this reminds me of when I was part of a beta testing program for a drum module that was released well before the features it promised were even capable. And while I was part of the 12 beta testers the project really lost its way and it always seemed like the end goal was never settled on. They never made a plan and stuck with it. By the time it realized its full potential it was discontinued shortly after. Though its still arguably the best and most realistic sounding E drum unit ever made.
I never wanted to try fractal. I know many people are happy with them. But with the latest effects on the quad I have no need for anything else. I also dont like that they are factory direct only. So you have no finance options and no place i can see one in person or have a easy no hassle return policy if Im not happy with it.
I mean the quad cortex isnt cheap. But its about half the cost of one truly world class amplifier. Less or more depending on your grail amp. But just like any modeler its not for everyone. But for those it is for its the perfect unit or at least as close to perfect as you could hope for. I just really hope development continues at a steady pace and that nothing need to be sacrificed.
I did notice that pre plugin compatibility the units power up time is a lot longer. But im not complaining. Because it gives me enough time to figure out I forgot to plug my guitar in before shit starts buzzing at 90db lol.
I second this fuly.
absolutely agree. It lacks simple things like assigning a color to each module, something really simple… better quality of effects, in particular reverbs and delays… a lot of simple stuff. I don’t care about plugins because I think you can sound good creating your own sound. They are missing a lot and they are opening too much the range, people want compatibility of plugins that give them everything they need to sound like this or that musician, it’s a public that doesn’t want the same as the professional that needs to achieve THEIR sound.
