Another output level topic (gain staging, gain unity, output level)
I couldn’t find any discussion that really answered my questions.
I read several forums and watched several videos about gain staging and unity gain, with a view to getting the most out of my Quad Cortex. Initially, I came to the conclusion that I needed to keep my final Path Output (Line) close to –12 dB. After playing at this level for a while, I realized that it didn’t give me much headroom when I activated a boost for a solo: clipping often occurred.
So I started reading up on the subject again and found that digital zero would actually be -18 dB, which seems very plausible to me considering the extra headroom I gain when I boost my guitar.
So my question is this:
I want to reduce the level of my presets already built into my Quad Cortex from -12 dB to -18 dB, and I’m wondering what’s the best way to do this without altering my tone.
Should I reduce the output level of my amp block?
Reduce the level of my Lane Output Control?
Add an EQ block at the end to reduce the level?
Thank you !
All three options that you mention would work without changing the tone. I use the output on the lane, but it’s a matter of taste.
And I came to the same conclusion: 12dB is a bit borderline if you need solos boosted.
