Adding notes (text based)
When entering a project, I keep notes on particulars… what if there was a means of adding notes in the cortex with the ability to attach them to whatever is relevant.
Example-
when using dream chorus in (st) turn sync off.
Or when using capture “whatever” dial bass -4 db with gain +3db.
Added notes could be indicated by quantity (perhaps) with a circled number by the block/preset/etc.
The notes could even be snapshots of a block to later be shared.
Im cleaned out of votes. Wonder if this would be helpful to anyone?
To simplify development, I would suggest to just have a simple text box for each preset, just to make quick notes for our future selves. So you can write down your comments/guitar settings/thoughts. Add a small button with an icon that brings up a empty fullscreen text field and the virtual keyboard. On top right a button to close it. Just like in the Cortex Cloud
I see that this has been discussed before in other aspects but I am not familiar with every pedal, cab, amp, etc, especially with the creative naming involved. I would like a note block that could be attached to the device name that I could add the actual maker and maybe the overall type of effect or sound I would get from it “Boss, clean tone, true bypass” “Marshall Hvy distortion, full gain”.
Right click, add/read note, 40 characters (?), and save.
It’s like you’re in my mind! I was about to post about this too, although for my use I’d like to be able to add notes that are visible in gig mode - for example what fret I need the capo on for which preset/scene (I play covers, so I tend to write the capo fret in the name of a scene, but there’s not much room to write things in the scene name; in the picture below ‘(Cp 2)’ means 'Capo 2nd fret;
Unfortunately I’m clean out of votes too (why is there a limit to the number of votes??)
