Hello all! I have recently acquired a Neural Quad Cortex which I will be using in 4 cable method in order to create a Hybrid rig (as seems to be the trend i.e Rabea’s Anderton’s video). I’m planning to use it mostly for its FX, modulation/drive in front of the amp and time based FX from the amp’s loop. Ideally I would use it along with a fuzz pedal and an analog delay pedal. Obviously the connection possibilities are documented on this forum and generally online.
My question is, would I be able to use it in 4 cable method with an audio switcher? What would the connections be in order to create this hybrid rig ?
The switcher in question has got loops 1-4 going in fron of the amp and loops 5-8 in the fx loop of the amp.
It depends on the audio switcher. Does it allow you to create 2 different paths from the loops?
The way this is hardwired is that loops 1-4 are intended for pedals in front of the amp and loops 5-8 for FX going through the amp’s loop
Then the answer is yes, you can
