I’m having an issue with my quad cortex and having an insane amount of feedback from my power amp/cab. Any time there is a pause or tight stops/starts in our music, you can hear the amp just screaming. It’s obviously frustrating when trying to have nice tight pauses, etc.
My setup consists of a QC (running a fairly basic patch of a Friedman amp, two gates, one on the input at the start of you chain and one after the amp block, sometimes I’ll throw on a green 808 but that usually when I’m just screwing around), and orange pedal baby and Mesa Trad 4x12. I have great tones built and I’m getting the sound I want. But I’m hesitant to not run this setup anymore due to the amount of unwanted high pitched squealing going on. I’m standing 12 feet away from my amp so I’m definitely not close enough to cause this. Gates are on, pickups really aren’t that hot, and we are loud as a band, but my previous tube amps never made this kind of unwanted feedback during playing. Am I missing something here? If anyone can steer me I. The right direction that would be awesome. Thanks and sorry for the long message.
The orange pedal baby doesn’t have tubes so tube microphonics are out of the way.
Next thing to check is wether the squealing happens when you turn down you guitar volume.
If the squealing stops on guitar volume down, I’d bet your pickups aren’t wax potted or aren’t wax potted enough.
The strange things is that I’ve used multiple guitars with different pickups. Both active and passive. My amp tech has told me that it’s just simply too much gain. I’ve run different paths on patches that involve dual amps, with overdrive pedals to tighten in up. Even as much to add up to 3 gates haha. Messing with the I/O levels. I’m just so confused on why I can’t make this thing stop screaming. I will definitely looking to the the wax potting as well.
Hey @BEABS ,
If you tried with active & passive guitars, then maybe the wax potting isn’t the issue (unless both of them don’t have any wax).
If your tech says too much gain, he might be on to something…
You might be facing a dilemma :
1 - you need all that gain : put a volume block to 0db (towards the end of the chain) that you can switch on when silence is required (like a mute switch). Maybe a momentary switch on the expression input (like a kill switch).
2 - you can live with less gain : turn the drives and gain down to a level where the guitars won’t squeal.
This problem can pop up with any modeler. I have definitely run into it before. My guess would be that either your input or output settings need to be dialed back or a level in one or multiple blocks in the preset is too hot.
I might try examining and then lowering the input or output gain if necessary. Move through your blocks and dial back level/gain settings.
Some blocks though, do tend to lend themselves more easily to this kind of thing. If parameter changes don’t help, another amp/pedal combination might just be the ticket if you can’t eliminate it.
I recently had a similar situation. I had my set up on an A/B switch to compare a capture I made to the actual amp.
I was running the capture through a SD solid state amp.
PS: I agree the captures always are noisy relative to the real deal. Very noisy.
I noticed tremendous feedback and squeal with the capture and none with the real amp.
I then turned down my tone knob (which was on 10) and it went away. I believe the D style power amps are more prone to high pitch squeal.
My next test will be to compare the same capture through the SD solid state power amp and then through the tube power amp using the Return on the loop. This way I can use the same QC capture and isolate if it’s the Power amp or the QC.
