Bumping. Assignable envelopes and LFOs would be lifechanging.
Add Expression to that list. I want to also use an expression pedal anywhere there is already an LFO (modulation fx). So you could assign to a phaser controlled by: LFO, ENV, Gate, or EXP
Please make this a thing.
I’m considering getting a QC, but the absence of control oscillators is pretty disappointing. I might just stick to the Zoia until this is implemented.
Bumping this. It would be super awesome helpful to have LFOs and envelopes which can be applied to block parameters. Especially in combination with the new Mono Synth block and even the bit crusher.
Make it happen pleeeeeease.
Would love to see this in a future release. Right now I need to buy a midi controller, which I really doesn’t want to do. Love the Flux function on the Helix and it would allow doing the same here.
YES, YES, and more YES… In fact, Fractal Audio products (and others) have LFOs.
Typically there are AT LEAST a half dozen of them available per preset that can be used on about any /every fx block. They add a TON of humanization to fx.
PLEASE Neural - DO NOT, do not, do not, do not… go making a few LFOs on a few fx blocks; PLEASE think BIGGER.
PLEASE don’t assume envelope followers always drive a parameter on an fx UP. PLEASE, please, please… as the my volume opens the envelope, I may want to drive some parameter down, or to a smaller volume. Example: I want a punchy gain or drive at the start of my note (or it is set at a high level with no sound input)… but…as the envelope opens up the gain is supposed to get smaller. Then when the envelope closes it resets to high or punchy again.
PLEASE don’t assume following an envelope always means going from a smaller to larger value for a knob; GIVE USERS THE FLEXIBILITY to set the envelope or use the envelope in reverse.
THIS!! Please give me this… I’m still hanging on to my mobius, primarily because i can’t make my guitar go WOB WOB with just the QC as is, right now… Give us this function PLEASE…
Bumping this - just wanted to play some Kirk solos with auto wah to avoid having to do a lot of work! ![]()
Neural made this statement upon release of CorOS 4.1.0:
…Now would be an EXCELLENT time to work on LFOs and the ability to map them to any parameter. We just got the Ring Modulator, which sounds great, but an LFO function applied to the Frequency control would push it over the top. I want the sound of my beloved Moogerfooger MF-102 without needing to wire this beast back onto my pedalboard.
Love this request. I just got my first QC and was a little saddened that sway reverb wasn’t to be found.
For anyone not familiar with this: https://youtu.be/LQCH9gOPrmw?t=156 (2:34 if the link doesn’t take you to the time directly)
Would love to replace my Supermoon Chrome with another QC effect vs having an extra pedal on the board.
This feature would be so amazing. It would really open up a lot of creative uses of guitar sounds.
Being able to lfo gain , eqs etc and then controlling the lfo parameters with a pedal would be so interesting to play with and give a unique edge to the QC.
also, add a random generator and pitch follower. this adds loads of possibilities as well. The envelope should have ADSR controls too. this would allow for finer control as you can use the release to make effects fade out slower than the envelope
