If not this would be really useful, for an IR you use again and again, as the list of IRs can be so long and they all have such similar names
For loaded IRs, you can rename them as something you like and remember, or add something next to the original name if you don’t want to alter it (I use an # next to my favorite IRs) ![]()
Good idea but that could be a very long winded process ![]()
You will only do it once, and then proceed marking the ones you like on the spot. Personally i don’t use/need more than 10 IRs
I really wish you could favorite captures too; I’ve downloaded so many from the cloud to try out; overdrives and amps, that it’d be great to be able to favorite some (I guess half the way to do it, is to just delete stuff which isn’t to your taste and you think you won’t use he he - need to spend a bit of time over Xmas weeding out the chaff)
My memory clearly isn’t what it was (or Neural are just very slow to listen and act on ideas - or both!) but turns out I posted this as a Feature Request a while back ![]()
