Hey all, when I switch to this specific preset/scene, I get flashing icons in the top right (below the undo icon). It looks IN, then IN with a red slash, then Mixer, then Mixer with a red slash. I have no idea what it’s trying to tell me, and the 4.1.1 user manual doesn’t seem to go that deep. Btw, I can use the scene as per usual. Any ideas would be greatly appreciated.
You’re running out of DSP so the master EQ on the output won’t be enabled
The Quad Cortex is organized into 2 cores allocated for the top two rows, and 2 cores allocated for the bottom two rows.
Also, the global EQ is handled by the same cores as the top two rows.
If you load up those rows in particular, or use a high amount of CPU across a whole preset, the QC will disable global EQ for that preset. The flashing you’re seeing is a visual indicator that it’s unavailable.
Aaah ok. Thanks! Not using any EQ on the output so, not a problem I guess. ha
Thanks for the in-depth response. I’ve only had my QC for about a week so I’m still getting used to things. Like how much CPU specific blocks take, and how to load-balance presets, etc. This helps a lot.
You can also show your CPU usage by enabling it within your settings. That will help you determine how to best setup your signal grid to be balanced across all cores.
