I am trying to configure a Roland FC-300 with a Quad Cortex via a CME H2MIDI in a similar fashion. I was able to get the pragram changes sorted out and I have one of the expression pedals on the Roland communicating (sort of) with the Quad.
When viewing the Wah block in Cortex Control I can see the signal being recieved in realtime, a green circle lights up from 0 to 100 representing the influence of the Roland’s expression pedal sweep (see pic). Unfortunately there is no affect on the guitar signal, no ‘wah’ effect. I have tried as many tweaks as I can think of, and I’m about to give up. There doesn’t seem to be anyway of directing the midi message from the Roland to be specifically applied to the Quad’s Wah sweep to make the tone changes.
Looks like Xush got it… I think it was the signal path. I had two ‘amps’: a neural capture in the first and an EVH in the second. When I started working with the Wah I disabled the Neural Capture thinking it would help me sort out how and what to configure (the wah was before both ‘amps’ I figured it would work) well… dumb move on my part. Once I re-enabled the Neural Capture in the first path… WAHHHHH WAHHHHH… TX for the comments everyone. I now have the Quad mounted safely in a padded, slide out rack and am controlling it via the Roland FC-300… very happy.
I figured you would get it to work. I use a Behringer FCB1010 (which is essentially a knockoff of a Roland FC-300) to control a lot of my QC, including using the two expression pedals for all kinds of stuff including wah effects. On the Behringer you have to calibrate the expression pedals before they will work well, I assume you did the same with the FCB-300?
I haven’t added the second expression yet but I will soon now that I have learned so many ways to get it WRONG.. LOL… And oddly no I didn’t do the calibration step and it works great. All I did was specify the range values in the roland and it worked flawlessly when I moved the pedal. BTW I’m using the Budda Wah knock off (Bubba Wha?) and it sounds reallly amazing.
Damn… I spoke to soon. The wah effect is working with the Roland FC-300 Exp pedal but I can’t get the ‘Toe Switch’ of the Roland exp pedal to switch the Quad’s wah effect on and off. Meaning the wah is ‘On’ all the time. What message must be configured/sent to disable/enable the wah block in the Quad? Is this not possible?
I don’t see anything in the list of incoming message values on the Quad:
