I’ve created a visual list of amplifiers in PDF format, but I don’t know how to share it.
Nice of you to do that, Yordi. May I suggest that you add the Neural model name for each amp, for reference? I don’t have a suggestion on the best place to post it.
Of the four columns from left to right, the third one is the name that represents that amplifier on the Quad Cortex. I think that’s the one you’re referring to? I’m working on the ones for Speakers, Pedals, and Microphones. I’ll try to find a way to post the link to download the PDF, which is much easier to read. Let’s see if anyone can help us.
Oops, obviously I wasn’t paying attention.
Nice work!
This could be an excellent addition to the QC Wiki if you are interested in sharing it there. I am not sure, however, if that Wiki is set up to handle images.
Oh yes, this is what I was looking for, thank you very much. I’m also creating the same table for speakers, pedals, and microphones. When I’ve finished them, I’ll upload them too. Thank you so much, mate!
Hi, just wondering if you were able to create the PDF as this would be an excellent source for reference
Si los tengo en PDF, pero no sé cómo hacer para compartirlos.
Hi, I have copied and pasted the image, 5 amps at a time, and put into Word and Photoshop. But the image needs to be a much higher resolution as the words are unreadable. I was then going to print it out.
So, if you could change the image to a much higher resolution and its readable, people can copy and paste and then print it out. Hope that helps
