Unable to Install Parallax on macOS
I just purchased Parallax and am very excited to use it in my production workflow; however, I’m unable to install the software on my iMac 5k 2017.
Running a macOS Catalina, Version 10.15.5 and using the current installer on the webpage (v1.0.0), below is the error message I’m receiving:
Any potential solutions for this issue other than reverting macOS?
I’m also having the same issue on Mac OS 10.15.15 - Mac Mini (2018) i5/64GB RAM/256GB SSD.
I’m able to get through the install to the point I receive this error by clicking “Allow” in Security and Privacy. Mac tries to block this install once or twice during the install…
Hi @enotfed.
I was able to get around this by disabling gatekeeper via the Terminal in Mac OS. Try this at your own risk…
  1. In terminal, paste the line below.
sudo spctl --master-disable
  1. Terminal might ask for your user password. If so, enter it.
  2. Install your Parallax software
  3. Re-enable Gatekeeper by entering the following in Terminal
sudo spctl --master-enable
@Gonzalo,
Thank you for your swift response and apologies for not being able to get back to you any sooner. I’m happy to confirm that this method worked for me and I didn’t have to go through the Terminal recommendation listed below.
@enotfed No problem! Glad to hear it worked.
