Stomp mode footswitch behaviour
I have 2 overdrives and an FX loop that are assigned to a footswitch in stomp mode. Pushing the footswitch toggles overdrive A off while turning overdrive B and FX loop on.
Is there a way to have the light on the footswitch illuminate when overdrive B and FX loop are on?
It always seems to default to being illuminated while overdrive A is on and the other two are off.
Thanks!
I’m assuming by “overdrives” you mean overdrive blocks in the QC; NOT an external overdrive pedal.
Remove the stomp assignment for all three blocks, then reverse the order of assigning these blocks so that overdrive B and FX loop correspond with the footswitch light. (This means that overdrive A will not have the same light.) Easy peasy.
