SLO100 plugin amp has noise
When I use the Soldano plug in in the QC, the clean channel has noise, like a buzz. The standalone plugin does not., it is clean
Running through same interface, same speakers, same settings.
tried different cabs, irs makes no difference. It isn’t amp distortion, it’s noise. Any ideas?I emailed support.
Following Support’s advice, I used only the QC for the interface, downloaded a repset from the plugin on computer, imported into the QC using Cortex Control, and found input levels too high on the Cortex.
Rooky mistake.
QC support is very good, and always responds in one day, usually with very good info.
