Device: Quad Cortex Mini
CorOS Version: 4.1.0
I’ve found a reproducible issue when using the Guitar Overdrive – John Mayer Justa Boost.
If the pedal is active and the BOOST parameter is set to ON, switching between Scenes causes a very noticeable delay. It takes almost 1 second for the Scene change to take effect.
If I disable the BOOST parameter, Scene switching returns to normal.
Steps to reproduce:
- Add Guitar Overdrive – John Mayer Justa Boost to a preset.
- Turn the block ON.
- Set BOOST = ON.
- Assign its parameters/state to Scenes.
- Switch between Scenes.
- There is a noticeable delay of almost 1 second before the new Scene takes effect.
- Set BOOST = OFF and repeat the test — Scene switching is normal again.
This is particularly noticeable when changing Scenes while playing and makes it difficult to use this effect for live performance.
I’ve attached a screenshot of the preset/block configuration.
Could you please check if this behavior can be reproduced?
