Preset Mixer View for Mixing Multiple Signal Chains
Hi~
I would like to request a mixer-style interface for balancing the signal chains created within a preset.
Quad Cortex already allows us to create multiple signal chains across the four rows, use parallel paths, and route them to different outputs. However, the level, pan, and routing controls are currently spread across individual output blocks and mixer nodes.
When using several chains at the same time, it can be difficult to see and adjust the overall balance of the preset.
It would be very useful to have a dedicated Preset Mixer View, where each row or completed signal path appears as a mixer channel.
For example, each channel could include:
  • Level fader
  • Pan control
  • Mute and Solo
  • Input and output meters
  • Output destination
  • Scene-assignable mixer settings
  • Optional Send and USB channel controls
This would not need to turn Quad Cortex into a full DAW. It would simply provide one central screen for mixing and monitoring the signal paths that already exist within a preset.
For users running multiple amps, parallel effects, stereo rigs, external devices through the effects loops, vocals, or separate FOH and monitor outputs, this would make Quad Cortex much easier and faster to manage.
The current Grid view would remain the main interface for building signal chains, while the Mixer view would be used for balancing those completed chains.
Awesome idea. But I think you better put this in the festure request area, so that we can vote for it
That would be awesome but I doubt this will be added. Development on QC is slow already. You probably better off getting Helix Stadium if you need this.
