CorOS Version: 4.0.1
Describe your issue:
Setting any IR Loader device (except the Lite versions) to Mute instead of Bypass does not behave as intended. Muted IR Loader blocks on the grid pass signal as if they’re bypassed.
- Add an IR Loader device to the grid. Dual/Single/M/ST doesn’t matter, just none of the Lite versions
- Swap the device from Bypass to Mute using the three dots in its parameter display
- Mute the device
- Pass audio through it
I expected this to happen:
Device’s output should be muted.
Toggling ‘Swap Mute/bypass’
Loading different configurations of IR Loader
Moving the device elsewhere on the grid
Messing with different routing configurations/lane outputs
Loading/unloading all IR slots in IR Loader
