Mono Multi-Output Option
Thank-you for adding the Multi-out feature in firmware 1.0.3.
The only problem is that since I use a mono power amp for on-stage monitoring, this feature is really not usable in my setup without a stereo sum box. Ideally this setup should work with minimal extra equipment and cabling.
It would be great if there were at least one multi-out mono option, so I’ll propose the following additional output options:
  1. Multi-out 1/2, 3, 4 (I.e. 1/2 stereo, 3 & 4 summed to mono).
  2. Multi-out Mono (i.e. 1,2,3,4 available as mono).
