Misha Mansoor X (troubleshooting)
I have been using Nolly & Tosin DSP models, But Misha Mansoor X will not run properly, it stutters like crazy and makes writing/recording impossible.
I’ve tried reinstalling twice and even in a fresh DAW session, it just kills my PC. I know it’s not my rig because I can run like 15 instances of the other DSPs.
It also runs fine in standalone which is bizarre to me.
Anyone else have this issue with the Misha model?
Hello
French user here :grin:
Similar issue here, for me and my son using different computers and DAWs…
I use the plugin with a Mac studio 64G /M1max with Cubase 14 and get CPU overloads (?) , my son is using logic pro with a M4 MacBook pro and Logic says that the plugin is not compatible (???!!!) and he will get crashes of his logic session !
I also get kind of weird noise while using the lead amp of the plugin, even with the noise gates full on and low gain settings, whatever guitar I use (active/passive SD or dimarzio PUs…)
Help wanted ! Thanks !
Edit : we also use Gojira, parallax and Fortin without any problem…
