Issues With Standalone Mode
Can anyone help me with this? https://youtu.be/SUy60BaXWs8
i cant contribute to standalone mode, but ive had a similar issue with plini in cubase. sky high process and same sound issue. but only with the clean amp and oversampling set to normal. oversampling in high position got rid of the sound issue.
after trial and error it seems my pc internal soundcard (realtek) was the problem (maybe the asio driver as well - havent tested) -> with disabeling my internal soundcard and only using my interface the problem was gone! i`ve also changed from cubase to reaper which brought cpu power done to a minimum.
are you using your internal soundcard or your interface?
