IR Impulse source
Hi
I’m just using for the first time some presets but they don’t come with IR Impulse.
There’s one here that is : YA MES 212 V30 Mix10.
Are these common IR’s that can be downloaded or are these presets worthless as they don’t come with the IR’s ?
You would need to purchase the 3rd party IRs and or just find a stock cab and tweak it.
costs $1 right now, if you really need it.
mes-212-v30-limited
An IR not being available in a downloaded preset, does not make the entire preset worthless. Should be really easy to add a Mesa 2x12 or 4x12 cab block. You would even benefit from having the microphone placement options in the block available to you.
you can find some free IRs here if you want to put a few on your QC to experiment with
Many Thanks Guys. I’ll have a look at those.
