IF YOU ARE LIKE ME (NOOB) and couldn’t figure out why the John Mayer plug-in was so volume senstive .. please read the below how to properly set this up. I am using a focusrite, but same concept for any system
(I wish neuraldsp had a “how to” video for us NOOBS, if they can use this for all the other NOOBS that bought this just for the JM plug in)
Steps:
- Turn your guitar all the way to 10
- Load the “focusrite control” or whatever UI interface you have. You need to be able to read how many decibles you are putting in.
- Turn your USB Interface *(UI)* down to ZERO on input. Ensure “Inst” is turn ON.
- STRUM REALLY HARD
- Your UI software will tell you how many decibles it is. In my case it was -23db.
- Turn up the input volume on your UI, STRUM REALLY HARD, until you hit just below clipping. Usually -6 or -9
- Take the difference of the two, (in my case -14, -23 vs -9)
- On the JM plugin, turn your input down by the difference (-14) and lock it.
Congrats, you can finally play it as it was meant to be played!
