CorOS Version: 4.1.0
Describe your issue:
Whenever I use the freeze block or the freeze function in Vintage Reverb it fails to hold indefinitely. It just slowly fades out.
- Create second path with bypass able gain block and freeze block in front and assign to footswitch, then activate freeze.
I expected this to happen:
When I unbypass the lane and freeze the signal it should hold as long as it’s engaged
- I have tried remaking preset
- I have tried moving the block elsewhere
- I have tried lightening the dsp load
- I have tried deleting the block on preset and adding it back.
