Midi customization where any parameter within any block can be custom set up for midi control. This is similar to the FAS method where each parameter can be manually set to a CC# and parameters can be controlled via midi.
ex. gain can be controlled via midi command.
This request exists multiple times over.
Quad Cortex is incredibly powerful, but its configurability is still limited. This makes many “power user workflows” that are possible with other machines cumbersome or even impossible when it comes to controlling the unit, especially via MIDI, where you can’t take advantage of the full power of your external MIDI controller.
The control system would benefit from a complete overhaul:
the non-reserved CC#s could be freely assigned to steer ANY parameter of whatever effect
please make so that a…
Using MIDI Messages to change effect parameter values.
This way, we won’t have to make completely new presets for small FX changes during songs (volume boost for solos, longer reverbs and delays, change delay settings from dotted 8th to 8th, etc.), and program multiple MIDI messages instead. This would save preset space, and would reduce the need to load different presets on stage.
Current users can use the NC as is, while more demanding users can make their required presets on the MIDI device…
