Feature Request: Add a "TC Electronic Infinite Style / EHX Freeze " Latching Mode to Freeze / Sustainer blocks
Hi everyone,
Requesting a new operational behavior for the Freeze/Sustainer utilities in the Quad Cortex, specifically mimicking the smart Latching Mode found on the TC Electronic Infinite Sample Sustainer for consideration.
Currently, the Quad requires a momentary hold or a standard on/off bypass toggle. While useful, implementing a dedicated latching mode with layering would open up incredible ambient and soundscape capabilities directly on the QC grid.
How it would work (based on the TC Infinite / EHX Freeze workflow):
  • Single Tap to Capture: A single tap on the designated footswitch instantly captures a snapshot of the current audio signal and holds it indefinitely as a pad. You do not need to hold your foot down.
  • Single Tap to Layer (Overdub): Tapping the footswitch again while a pad is active captures a new snapshot and layers it on top of the original, letting you dynamically build chords or evolving soundscapes.
  • Double Tap to Clear: Double-tapping the footswitch kills the freeze engine entirely and fades the sustained pad out naturally based on a configurable decay setting.
Thanks
