Hello, I have a MINI. I want to put a MiniCryBaby AutoReturn through Effects Loop. But the signal damages me a lot. Any recommendations?
Can you describe in more detail what you mean by this? Do you mean to say that it doesn’t sound good?
Another question: where are you putting the effects loop in relation to whatever amp or overdrive blocks you have in the grid? Wahs are typically used in front of those.
I’m putting it first in the chain. But even off, the sound of the Neural changes a lot
…Why not put the wah in front of the QC? Fewer DAC / ADC processes.
Got the same issue. I play different guitars and every guitar uses another input. So I switch them by changing presets which means I need to put the wah into the loop. But since the new update, it sounds horrible. Can’t use wah any more since the sound chances drastically and not really in a good direction.
